Sinumerik Alarm 16922 Channel %1 subprograms: action %2 maximum nesting depth exceeded
Various actions can cause the current procedure to be interrupted. Depending on the action, asynchronous subroutines are activated. These asynchronous subroutines can be interrupted in the same manner as user programs. Unlimited nesting depth is not possible for asynchronous subroutines due to memory limitations. Example: An interrupt interrupts the current program processing. Other interrupts with higher priorities interrupt processing of the previously activated asynchronous subroutines. Possible actions are: DryRunOn/Off, Decode Single BlockOn, delete distance-to-go, interrupts …..
Do not trigger the event on this block.
