Sinumerik Alarm 16932 Channel %1 conflict when activating user data type %2
%2 = Data type
The “activate user data” function (PI service _N_SETUDT) modifies a data block (tool off- set, settable zero offset or base frame) which is also written by the NC blocks in preparation. In the event of a conflict, the value entered by the MMC is reset. Parameter %2 specifies which data block is affected: 1: Active tool offset 2: Base frame 3: Active zero offset
Check the inputs on the MMC and repeat if necessary.
