Sinumerik Alarm 16948 Channel %1 dependent channel %2 still active
%1 = Channel ID
%2 = Channel ID
This alarm is active with “Group Serupro” only. “Group Serupro” is activated by means of “$MC_SERUPRO_MODE BIT2” and enables the retrace support of entire channel groups during block search. A “dependent channel” is a channel that had indirectly been started by the currently active channel. The currently active channel was started via PLC. This channel m_u_s_t be terminated (i.e. reached M30) before the current channel is terminated. This alarm occurs if the currently active channel is terminated before the dependent channel.
Switch off “Group Serupro” (see $MC_SERUPRO_MODE) or install WAITE.
