Sinumerik Alarm 16949 Correspondence between marker of channel %1 and channel %2 is invalid.
%1 = Channel ID
%2 = Channel ID
This channel defines a WAIT marker with other channels, which on their part have no correspondence with this wait marker. This channel’s WAIT marker has no explicit counterpart in the other channel; i.e.
the channels do not mutually wait.
Example Ch 3 Ch 5 Ch 7
WAITM(99,3,5) WAITM(99,3,5) WAITM(99,5,7)
The wait markers in channels 3 and 5 mutually wait for each other and channel 7 only waits for channel 5. Therefore, channel 7 may continue when 5 and 7 have reached the wait marker, but channel 3 is still far in front of the wait marker. When it continues, channel 7 deletes its wait marker. When wait marker 99 is reached again, you can no longer determine the behavior precisely.
In each wait marker, list all channels with which you want to synchronize, or suppress the alarm with $MN_SUPPRESS_ALARM_MASK, bit 23.
Sample solution A:
Ch 3 Ch 5 Ch 7
WAITM(99,3,5,7) WAITM(99,3,5,7) WAITM(99,3,5,7)
Sample solution B:
Ch 3 Ch 5 Ch 7
WAITM(99,3,5) WAITM(99,3,5) WAITM(88.50.7) WAITM(88.50.7)
Sample solution C:
Ch 3 Ch 5 Ch 7
WAITM(88.50.7) WAITM(88.50.7) WAITM(99,3,5) WAITM(99,3,5)
Clear alarm with the Delete key or NC START
