Sinumerik Alarm 17010 Channel %1 block %2 no memory left
When executing/reading files from the active working memory, it was found that there is not enough memory space (e.g. for large multidimensional arrays or when creating tool offset memory).
Please inform the authorized personnel/service department. Make arrays smaller or make more memory space available for memory management of subroutine calls, tool offsets and user variables (machine data MM_…). See /FB/, S7 Memory Configuration
