Sinumerik Alarm 17040 Channel %1 block %2 illegal axis index
A read or write access has been programmed to an axial variable in which the axis name cannot be unambiguously imaged on a machine axis. Example: Writing of an axial machine data $MA_… [X]= … ; but geometry axis X cannot be imaged on a machine axis because of a transformation!
Deselect transformation before writing the axial data (keyword: TRAFOOF) or use the machine axis names as axis.
