Sinumerik Alarm 17080 Channel %1 block %2 %3 value below lower limit
%3 = MD
An attempt was made to write a machine data with a value that is smaller than the defined lower limit.
Please inform the authorized personnel/service department. Determine the input limits of the machine data and assign a value within these limits.
