Sinumerik Alarm 17110 Channel %1 block %2 digital output no. %3 not activated
%3 = No. of output
An attempt was made to read or set a digital NCK output (connector X 121) via the system variable $A_OUT [n] with the index [n] greater than the specified upper limit in the NCK machine data 10360 FASTIO_DIG_NUM_OUTPUTS.
Program index [n] of the system variable $A_OUT [n] only between 0 and the value in the NCK machine data 10350 FASTIO_DIG_NUM_OUTPUTS.
