Sinumerik Alarm 17140 Channel %1 block %2 NCK output %3 is assigned to a function via machine data
%3 = No. of output
The programmed digital/analog output is assigned to an NC function (e.g. software cams).
Please inform the authorized personnel/service department. Use another output or deactivate concurrent NC function via MD.
