Sinumerik Alarm 17180 Channel %1 block %2 illegal D number
In the displayed block, access is made to a D number (tool edge number) that is not initialized and therefore is not available.
Check tool call in the NC part program:
• Correct tool edge number D.. programmed? If no tool edge number is specified, then D1 is automatically active.
• Tool parameters P1 – P25 defined? The dimensions of the tool edge must have been entered previously either through the operator panel or through the V.24 interface. Description of the system variables $P_DP x [n, m] n … Associated tool number T m … Tool edge number D x … Parameter number P
