Sinumerik Alarm 17182 Channel %1 block %2 illegal sum correction number
An attempt was made to access a non-defined total offset of the current tool edge.
Access the total offset memory with $TC_SCP*, $TC_ECP*, check the total offset selection DLx or tool selection Ty or offset selection Dz.
