Sinumerik Alarm 17188 Channel %1 D number %2 defined in tool T no. %3 and %4
%2 = Offset number D
%3 = T number of first tool
%4 = T number of second tool
The specified D number %2 in the TO unit of channel %1 is not unique. The specified T numbers %3 and %4 each have an offset with number %2. If tool management is active: The specified T numbers belong to tool groups with different names.
1. Ensure that the D numbers within the TO unit are unique.
2. If unique numbering is not necessary for subsequent operations, do not use the command.
