Sinumerik Alarm17190 Channel %1 block %2 illegal T number
In the displayed block, access is made to a T number (tool number) that is not initialized and therefore not available.
Check tool call in the NC part program:
• Correct tool number T.. programmed?
• Tool parameters P1 – P25 defined? The dimensions of the tool edge must have been entered previously either through the operator panel or through the V.24 interface.
Description of the system variables $P_DP x [n, m]
n … Associated tool number T
m … Tool edge number D
x … Parameter number P
