Sinumerik Alarm 17200 Channel %1 block %2 deleting tool data not possible
An attempt has been made to delete from the part program the tool data for a tool currently being processed. Tool data for tools involved in the current machining operation may not be deleted. This applies both for the tool preselected with T or that has been changed in place of another, and also for tools for which the constant grinding wheel peripheral speed or tool monitoring is active.
Check access to tool offset memory by means of $TC_DP1[t,d] = 0 or deselect tool.
