Sinumerik Alarm 17262 Channel %1 block %2 illegal tool adapter operation
If an attempt is made to define or cancel a tool adapter assignment with reference to a magazine location and this magazine location already has another tool adapter and/or a tool is located in the adapter or – when canceling an assignment – a tool is still at the location, this alarm will appear. If machine data $MC_MM_NUM_SUMCORR has the value -1, adapters cannot be generated by a write operation to an adapter which is not already defined. While the machine data has this value, you can only write adapter data to adapt- ers which have already been (automatically) assigned to magazine locations.
• Assign a maximum of one adapter to a magazine location.
• The magazine location must not contain a tool.
• Machine data $MC_MM_NUM_SUMCORR has value -1: If an alarm occurs when writing one of the system parameters $TC_ADPTx (x=1,2,3,T), the write operation must be modified such that only adapter data which are already associated with the magazine locations are written.
