Sinumerik Alarm 17270 Channel %1 block %2 call-by-reference: illegal variable
Machine data and system variables must not be transferred as call-by-reference parameters.
Modify NC program: Assign the value of the machine data or of the system variable to a program-local variable and transfer this as parameter.
