Sinumerik Alarm 17600 Channel %1 block %2 preset on transformed axis %3 not possible
The displayed axis is involved in the current transformation. This means that is it not possible to set the actual value memory (preset) for this axis.
Example: Machine axis A should be set to the new actual value A 100 at the absolute position A 300. : N100 G90 G00 A=300 N101 PRESETON A=100
Avoid preset actual value memory for axes which are participating in a transformation or deselect the transformation with the keyword TRAFOOF.
