Sinumerik Alarm 17605 Channel %1 block %2 axis %3 transformation active: inhibits rotation of axis container
The programmed axis/spindle is active in a transformation and the axis container cannot be rotated for this reason.
Modify part program. Deactivate the transformation for this axis/spindle before rotating the axis container or perform the axis container rotation later.
