Sinumerik Alarm 17610 Channel %1 block %2 axis %3 involved in the transformation, action cannot be carried out
The axis is involved in the active transformation. It can therefore not execute the demanded action,traversing as positioning axis, enable for axis replacement.
Deselect the transformation with TRAFOOF ahead of time or remove the action from the part program block
