Sinumerik Alarm 17620 Channel %1 block %2 approaching fixed point for transformed axis %3 not possible
%1 = Channel number %2 = Block number, label %3 = Axis name, spindle number
In the displayed block, an axis is programmed for the fixed point approach (G75) that is involved in the active transformation. Fixed point approach is not performed with this axis!
Remove G75 instruction from the part program block or previously deselect transformation with TRAFOOF.
