Sinumerik Alarm 17900 Channel %1 block %2 axis %3 is no machine axis
%1 = Channel number %2 = Block number, label %3 = Axis name, spindle number
At this point, the block context calls for a machine axis. This is the case with:
• G74 (reference point approach)
• G75 (fixed point approach) If a geometry or additional axis identifier is used, then it must also be allowed as machine axis identifier (MD 10000 AXCONF_MACHAX_NAME_TAB).
– Alarm display. – Interface signals are set. – Interpreter stop – NC Start disable in this channel.
Use machine axis identifier when programming.
