Sinumerik Alarm 18100 Channel %1 block %2 invalid value assigned to FXS[ ]
%1 = Channel number %2 = Block number, label
The following values are valid at the present time: 0: “Deselect traverse against fixed stop” 1: “Select traverse against fixed stop” valid.
