Sinumerik Alarm 18201 Channel %1 block %2 curve table: table %3 does not exist
%3 = Number of curve table
An attempt was made to use a curve table whose table number is not known in the system \par.
Change the table number in the program instruction or define the curve table with the desired table number.
