Sinumerik Alarm 20062 Channel %1 axis %2 already active
The displayed axis is already traversing as a machine axis. Therefore, it cannot be operated as a geometry axis. Traversing of an axis can take place in JOG mode through 2 different interfaces. 1. as a geometry axis: via the channel-specific interface DB 21 – DB 28, DBX12.6 or DBX12.7 2. as a machine axis: via the axis-specific interface DB 31 – DB 48 DBX8.6 or DBX8.7 With the standard machine control panel, it is not possible to operate an axis as machine axis and geometry axis at the same time.
Do not start the geometry axis until the traversing motion as machine axis has been concluded.
