Sinumerik Alarm 20079 Channel %1 axis %2 oscillation path length %3 <= 0
Sinumerik Alarm 20079 Channel %1 axis %2 oscillation path length %3 <= 0 Parameters:
%2 = Axis number
%3 = Length
The axis is traversed as an oscillating axis and the distance to be traversed is smaller than or equal to zero. For example, both reversal points are situated on an identical position, one reversal point was shifted against the oscillating direction beyond the other reversal point. The axis is not traversed.
– Local alarm reaction.
Specify correct target position (reversal position, end position).
