Sinumerik Alarm 20090 Axis %1 travel to fixed stop not possible. Check programming and axis data.
1. The “Traverse against fixed stop” function has been programmed with FXS[AX]=1 but the axis does not (yet) support this. Check MD 37000. This function is not available for gantry axes and simulated axes.
2. On selection, no movement was programmed for axis AX. AX is a machine axis identifier.
3. It is always necessary to program a traversing movement in the selection block for the axis/spindle for which the “Traverse against fixed stop” function is activated. The alarm can be reprogrammed in the MD ALARM_REACTION_CHAN_NOREADY (channel not ready).
– Mode group not ready.
• Check the axis type.
• Check MD 37000.
• Is a machine axis movement missing in the approach block?
