Sinumerik Alarm 20094 Axis %1 function has been aborted
The function has been aborted. The possible reasons for this are:
• Because a pulse disable has occurred, the torque can no longer be provided.
• The PLC has removed the acknowledgments. The alarm can be reprogrammed in the MD ALARM_REACTION_CHAN_NOREADY (channel not ready).
– Mode group not ready.
Check whether
• there is a pulse disable from the infeed/regenerative-feedback unit or from the PLC?
• the acknowledgement bits have been deleted by the PLC even though NCK has not requested deselection?
