Sinumerik Alarm 20120 Axis %1: too many compensation relations
IInterpolatory compensation with tables. For each axis, the maximum number of compensation relationships defined may be no more than the number of axes in the system. In this alarm, the interpolatory compensation in the axis is switched off automatically.
Check table parameters $AN_CEC_OUTPUT_AXIS and correct and/or switch off one or more tables ($SN_CEC_TABLE_ENABLE).
