Sinumerik Alarm 20125 Axis %1: change of compensation value is too rapid
The compensation value has changed more rapidly than has been allowed for in 32730 CEC_MAX_VELO. It had to be limited temporarily. The missing section is repeated later but contour errors might have occurred.
Check characteristic data of the compensation tables assigned to the axis. Check characteristic curves in the tables ($AN_CEC). Possibly one of the input axes has moved more rapidly than provided for.
