Sinumerik Alarm 20141 Channel %1 motion synchronous action: illegal axis type
The requested command is not permissible in the current axis status for the command axis or spindle. This alarm occurs with command axes (POS, MOV), spindle commands from motion synchronous actions (M3/M4/M5, SPOS), coupled motion (TRAILON, TRAILOF) and lead value coupling (LEADON, LEADOF).
First stop the axis or deactivate the coupling, then select a new status.
