Sinumerik Alarm 20142 Channel %1 command axis %2: rotation of axis container already enabled
%2 = Axis Definitions: The synchronized action instruction is not allowed on a spindle enabled for the axis container rotation. The alarm only occurs if the spindle is handed to another NCU.
Initiate the synchronized action instruction before the axis container rotation enable or after the end of the rotation (depending on the application).
