Sinumerik Alarm 20149 Channel %1 block %2 motion synchronous action: illegal index
%2 = Block number
An invalid index was used for access to a variable in motion synchronous action. Example: … DO $R[$AC_MARKER[1]] = 100 This error occurs if the value of marker 1 is greater than the maximum permissible R parameter number.
Use a valid index.
