Sinumerik Alarm 20201 Channel %1 spindle %2 no tool assigned
%2 = Spindle number
In order to make allowance for the fine tool compensation for the tool currently in the spindle, a spindle/tool assignment must be active. This is not presently the case for the programmed spindle in the target channel of fine tool compensation.
1. Modify the part program (write the tool fine compensation).
2. Establish spindle/tool assignment by programming: • TMON (tool monitoring) • GWPSON (tool selection)
