Sinumerik Alarm 2130 5V/24V encoder or 15V D/A converter under voltage
A failure has occurred in the power supply (FM357-2) to the encoder (5V/24V) or D/A converter (+/-15V).
– Axes of this channel must be re-referenced.
Please inform the authorized personnel/service department.Check the encoder and cable for short-circuits (the fault should not occur when you remove the cable).Check the power feeder line.
