Sinumerik Alarm 21610 Channel %1 axis %2 encoder %3 frequency limit exceeded
%3 = String (encoder number)
The maximum permissible frequency of the currently active encoder (axis-specific inter- face signal DB 31 – 48, DBX 1.5 and DBX 1.6) in the axis-specific machine data 36 300 ENC_FREQ_LIMIT [n] (n … encoder number, 1 or 2) has been exceeded. The reference of the actual value to the mechanical carriage position may be lost. The alarm can be reprogrammed in the MD ALARM_REACTION_CHAN_NOREADY (channel not ready).
– Mode group not ready.
Modify MD 36300: ENC_FREQ_LIMIT [n] and interface signal position measuring system 1/2 (DB 31 – 48, DBX 1.5 and DBX 1.6).
