Sinumerik Alarm 21617 Channel %1 block %2 transformation does not allow to traverse the pole
The preset curve passes through the pole or a forbidden area of the transformation.
– Local alarm reaction.
Modify part program (if alarm has occurred in AUTO mode). To escape from the alarm position, transformation must be deselected (it is not enough to try a RESET if the transformer remains active when RESET is applied).
