Sinumerik Alarm 21660 Channel %1 block %2 axis %3 conflict between SYNACT: $AA_OFF and CORROF
%3 = Axis name
When deselecting the position offset ($AA_OFF) via the part program command COR- ROF (, “AA_OFF”) an active synchronized action is detected that immediately sets $AA_OFF for the axis (DO_$AA_OFF [] =). Deselection is executed and $AA_OFF not set again.
– Local alarm reaction.
Modify part program.
