Sinumerik Alarm 21665 Channel %1 $AA_TOFF cleared
If the tool position is changed with RESET and $AA_TOFF is active during RESET, the position offset ($AA_TOFF) is cleared.
– Local alarm reaction.
Modify the RESET setting in $AA_TOFF_MODE.
