Sinumerik Alarm 21670 Channel %1 block %2 illegal change of tool direction with $AA_TOFF active
If an offset has been activated in tool direction by means of $AA_TOFF[i], no block is allowed to be activated in which the offset axis assignment i is modified (plane change, tool change cutting tool <=> turning tool, transformation change, TRAFOOF, TCARR=0, geometry axis change)
– Local alarm reaction.
• Modify part program
• Program TOFFOF()
