Sinumerik Alarm 21701 Channel %1 block %3 axis %2 measurement not possible
%3 = Block number
Measurement level 2 (MEASA, MEAWA, MEAC). There is an error in the programmed measurement task.
Possible causes:
• Invalid measurement mode
• Invalid probe
• Invalid encoder
• Invalid number of measurement signal edges
• Identical measurement signal edges are only programmable in mode 2
• Invalid FIFO number
• Mismatch between the number of FIFOs programmed and the number of probes used in the measurement task.
Further causes:
• A measurement task is already active (e.g. from a synchronized action).
– Local alarm reaction.
Correct the measurement tasks.
