Sinumerik Alarm 21740 Output value at analog output no. %1 has been limited
%1 = No. of output
The value range of the analog output n is limited by machine data 10330 FASTIO_ANA_OUTPUT_WEIGHT[n].
With $A_OUTA[..] = x no greater values can be programmed than permitted in the respective machine data.
