Sinumerik Alarm 22040 Channel %1 block %3 spindle %2 is not referenced with zero marker
%3 = Block number, label
The current position is not referenced with the MS position although reference is made to it.
Correct NC part program. Create the zero mark synchronization by positioning, by rotation (at least 1 revolution) in speed control mode or G74 before switching the alarm generating function on.
