Sinumerik Alarm 22050 Channel %1 block %3 spindle %2 no transition from speed control mode to position control mode
%3 = Block number, label
• An oriented spindle stop (SPOS/SPOSA) has been programmed or the position control of the spindle was switched on with SPCON but no spindle encoder has been defined. • When switching on the position control, the spindle speed is greater than the limiting speed of the measuring system.
Spindle without attached encoder: Any NC language elements requiring the encoder signals must not be used. Spindle with attached encoder: Enter the number of spindle encoders used in the MD NUM_ENCS.
