Sinumerik Alarm 22051 Channel %1 block %3 spindle %2 reference mark not found
%3 = Block number, label
When referencing, the spindle turned through a greater distance than given in the axis- specific machine data 34060 REFP_MAX_MARKER_DIST, without receiving a reference mark signal. The check is performed for spindle positioning with SPOS or SPOSA when the spindle has not previously run with speed control (S=…).
Please inform the authorized personnel/service department. Check and correct the machine data 34060 REFP_MAX_MARKER_DIST. The value entered states the distance in [mm] or [degrees] between 2 zero markers.
