Sinumerik Alarm 22062 Channel %1 axis %2 reference point approach: zero marker search velocity (MD) is not reached
The configured zero marker search velocity is not reached.
Please inform the authorized personnel/service department. Check active spindle speed limitations. Configure a lower zero marker search velocity $MA_REFP_VELO_SEARCH_MARKER. Check the tolerance range for the actual velocity $MA_SPIND_DES_VELO_TOL. Set a different referencing mode $MA_ENC_REFP_MODE != 7.
