Sinumerik Alarm 22064 Channel %1 axis %2 reference point approach: zero marker search velocity (MD) is too high
The configured zero marker search velocity is too high. The encoder limit frequency is exceeded for the active measuring system.
Please inform the authorized personnel/service department. Configure a lower zero marker search velocity $MA_REFP_VELO_SEARCH_MARKER. Check the encoder frequency configuration $MA_ENC_FREQ_LIMIT and $MA_ENC_FREQ_LIMIT_LOW. Set a different referencing mode ($MA_ENC_REFP_MODE != 7).
