Sinumerik Alarm 22200 Channel %1 spindle %2 axis stopped during tapping
When tapping with compensating chuck (G63) the drilling axis was stopped via the NC/ PLC interface and the spindle continues to rotate. The thread and possibly also the tap were damaged as a result.
Please inform the authorized personnel/service department. Provide an interlock in the PLC user program so that no axis stop can be initiated when tapping is active. If the tapping operation is to be terminated under critical machine conditions, the spindle and the axis should be stopped simultaneously if at all possible. Slight differences are then accommodated by the compensating chuck.
