Sinumerik Alarm 25050 Axis %1 contour monitoring
The NCK calculates for each interpolation point (setpoint) of an axis the actual value that should result based on an internal model. If this calculated actual value and the true machine actual value differ by a larger amount than given in the machine data 36400 CONTOUR_TOL, then the program is aborted and the alarm message is issued. The alarm can be reprogrammed in the MD ALARM_REACTION_CHAN_NOREADY (channel not ready).
– Mode group not ready.
• Check whether the tolerance value set in MD 36400: CONTOUR_TOL is too small.
• Check optimization of the position controller (Kv factor in the machine data 32200 POSCTRL_GAIN) to establish whether the axis follows the given setpoint without over- shooting. Otherwise, the speed controller optimization must be improved or the Kv servo gain factor must be reduced.
• Improvement of speed controller optimization
• Check the mechanics (smooth running, inertial masses).
