Sinumerik Alarm 25201 Axis %1 drive fault
The drive signals a serious fault of status class 1 (ZK1). The exact cause of the fault can be recognized by evaluating the following drive alarms which are output in addition: Alarm 300 500, alarms 300 502 – 300 505, alarm 300 508, alarm 300 515, alarm 300 608, alarm 300 612, alarm 300 614, alarms 300 701 – 300 761, alarm 300 799. The alarm can be reprogrammed in the MD ALARM_REACTION_CHAN_NOREADY (channel not ready).
– Mode group not ready.
Evaluation of the drive alarms listed above.
