Sinumerik Alarm 26007 Axis %1 QEC: invalid coarse step size
The course step width for QEC must be within the range 1 <= course step width <= maxi- mum value of MD 18342 MM_QEC_MAX_POINTS (currently 1025), because a greater number of values would exceed the available memory space. Reactions:
Modify the system variable $AA_QEC_COARSE_STEPS accordingly.
